Date/Time: Thu, 28 Nov 2024 15:36:22 +0000
bpoc poc extension lines change color
View Count: 406
[2023-04-13 23:21:41]
User303857 - Posts: 74
Hello Support
Is it possible to have the bpoc poc extension lines automatically change color for each new bar ?
For example:
If bar poc is above the vwap mid line then color extension lines green &
If bar poc is below the vwap mid line then color color extension lines red.
If candle is a up candle then color bar poc extension lines green &
If candle is a down candle then color bar poc extension lines red.
Thank You
[2023-04-14 14:17:26]
John - SC Support - Posts: 36350
There is not a way to change the color of the extension lines, except through the Subgraph controls for the extension lines in the study itself. In other words, you can not use a study like "Color Bar Based on Alert Condition" to change the color based on a condition.
Using a custom study, you would have to find the POC and then generate the extension lines and set the color as you want when you generate the line. Refer to the following:
sc.AddLineUntilFutureIntersection()
