Date/Time: Thu, 28 Nov 2024 15:48:46 +0000
Natural Gas, Oil and Equities
View Count: 407
[2023-04-13 11:43:12] |
User266447 - Posts: 254 |
Where can I find symbol for natural gas, crude oil and shares from the US, DAX and FTSE100. I am not sure if you have Polish WIG20 and access to Polish equities?
[2023-04-13 15:34:33] |
To find symbols within Sierra Chart, you need to use the "File >> Find Symbol" window. Refer to the following: File Menu: Find Symbol (File) We do not have data for any Polish instruments of any kind. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-04-14 12:34:10] |
What is the symbol for oil and natural gas? Or which exchanges can I find them?
[2023-04-14 16:26:50] |
The actual symbol will depend on your trading service. But go to File >> Find Symbol and open the section for Futures - NYMEX and find the particular symbol you are looking for.
