Date/Time: Thu, 28 Nov 2024 18:50:13 +0000
Volume for 10y treasury - is not correct
View Count: 249
[2023-04-13 10:01:59] |
Stefan Alexandru Ilie - Posts: 1 |
Hello, A kind request for advice, For the 10y Treasury ZNM23-CBOT - Expiry June 2023 - i am seeing a volume of around 188k. i expect this figure to be much higher ( i.e. over 1M) . Would you please advice, what is the correct current volume for 10y Treasury ZNM23-CBOT? and what i need to change to see the correct volume. Kind Regards, Alexandru Ilie Date Time Of Last Edit: 2023-04-13 10:08:16
Logs_13_April_2023.txt - Attached On 2023-04-13 10:01:13 UTC - Size: 149.69 KB - 183 views Volume_QuoteBoard.JPG / V - Attached On 2023-04-13 10:08:13 UTC - Size: 327.94 KB - 68 views |
[2023-04-13 10:11:56] |
Sierra_Chart Engineering - Posts: 17206 |
Contact the exchange with your question. We can provide no help at all with this. The volume that you see on a Quote Board comes from the exchange.
