Date/Time: Thu, 28 Nov 2024 15:42:39 +0000
Cumulative Last Size Overlay Total Volume
View Count: 381
[2023-04-12 19:50:01]
User547290 - Posts: 58
I would like to put the Cumulative Last Size (overlay) the Current Traded Total Volume on the Ladder. Is there anyway of doing this or are you planning on being able to do this in the near future?
I would like to reduce the width of the ladder so I can have more ladders on one screen and my eye does not have to keep bouncing from column to column. This would be helpful.
Basically Combine the Total Volume Column with the Cumulative Last Size Column.
imageEpicPen_cKTM2CwRa0.png / V - Attached On 2023-04-12 19:49:08 UTC - Size: 47.72 KB - 86 views
[2023-04-13 14:39:39]
John - SC Support - Posts: 36350
Refer to the following:
Global Trade Settings Windows: Display Cumulative Last Size in Current Traded Total Volume (Global Settings >> Chart DOM Settings >> Other >> Other Settings)
There is not a way to change the width of the ladder - this is handled automatically by the system. And you can only have one ladder on the right and another on the left (Chart Settings: Use Left Side Scale (Chart >> Chart Settings >> Scale menu)).
[2023-04-14 18:50:36]
I think you missed my point. I know how to adjust the width of the column's on the Trade DOM. I want to place the Cumulative Last Size in the Total Volume column over the top of the histogram and numbers in the same column. This way I can eliminate a column if the two are in the same column. If you look at the "Trading Technologies" Ladder this is what they do. It is helpful.
[2023-04-14 20:12:38]
The Cumulative Last Size is only ever a single number. So the setting we pointed you to will display that value in the Current Traded column, thereby combining the two columns. We do not know exactly what Trading Technologies does, or how they handle this. But this is what we have available.
[2023-04-14 20:20:48]
I found what I was looking for. It is under settings for the DOM.
Now I can get rid of one of the columns.
imageEpicPen_Tv0KEw47fo.png / V - Attached On 2023-04-14 20:20:08 UTC - Size: 23.94 KB - 88 views
