Date/Time: Fri, 22 Nov 2024 17:53:39 +0000
Base Standard Sierra Chart (Service Package 3)
View Count: 452
[2023-04-12 02:53:32] |
User585993 - Posts: 83 |
I just need another account to copy my trades, in other words, basic graphs, and top-of-the-book data, will this package be enough?
[2023-04-12 14:58:17] |
John - SC Support - Posts: 36222 |
We are not fully understanding what you are wanting to do, but if you do not need to access a trading account or get real-time data, then one of the Base packages will work. Whether you need Standard or Advanced package depends on whether you need certain studies (Numbers Bars and TPO are the major differences). Refer to the information for the Base packages here: Description of Service Packages and Pricing: Base Packages For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-09-28 09:36:49] |
micul - Posts: 1 |
Hello, i need help, i want to do a subscription to sierra chart, but a need also the TPO indicator for my strategy. The basic subscrition (service pack 3) has the TPO? Or i need the fifth pack?
[2024-09-28 14:19:44] |
Sierra_Chart Engineering - Posts: 17145 |
You will need Service Package 5.
