Date/Time: Thu, 28 Nov 2024 18:42:39 +0000
Setting that slwos Siera...
View Count: 347
[2023-04-11 15:04:16] |
User75949 - Posts: 118 |
Some days ago I experienced some slowing of Sierra Chart then solved remaking from scratch some Chartbooks here the thread Sierra slowing 'cause of long term intraday chart Now I think I found who was mainly responsible for slowing the thing: On an intraday chart (5000 contracts candle chart) on the daily Volume Profile if I set "Extend Ponit Of Control" and "Future Intersection" in Volume Profile or even worst on "chart bars" it stars to slow... A bit better than the old chartbook but I see that it starts to burden the software. If I set back "Extend Point Of Control" to NONE everything comes back to completely fluid Which could be the reason? That setting is pretty useful... tks regards R. |
[2023-04-11 21:58:39] |
Sierra_Chart Engineering - Posts: 17204 |
How many days of data is loaded in the chart?
[2023-04-11 23:14:35] |
1500 days continuous contract... but all other indicator are fine... |
[2023-04-12 07:34:54] |
We do not think we can help with better performance. That is a large number of days.
[2023-04-12 09:28:04] |
ok, I understand, even if I was thinking it was not a big issue for Sierra, because once calculated I thought it shouldn't burden the system, Anyway I found the solution I calculated the daily volume profile on only 200 days, and the composite profile on all 1500 days, in this way it works fine. Tks anyway regards R. |
