Date/Time: Thu, 28 Nov 2024 17:38:38 +0000
the same number of graphs
View Count: 300
[2023-04-11 15:01:38]
Daniel Kamiński - Posts: 25
why do all graphs have the same number? I would like to copy the drawings but they have the same number :)
Regards,
DK
imagechart.png / V - Attached On 2023-04-11 15:01:05 UTC - Size: 119.69 KB - 66 views
imagechartOF.png / V - Attached On 2023-04-11 15:01:13 UTC - Size: 141.83 KB - 71 views
[2023-04-11 16:00:35]
John - SC Support - Posts: 36350
You are looking at charts between Chartbooks. Within a Chartbook the charts will have different numbers, but between chartbooks they may be the same.
Still, you can copy drawings between chartbooks. Refer to the information at the following link (5th paragraph):
Chart Settings: Copy Chart Drawings from Chart #'s (Chart >> Chart Settings >> Chart Drawings menu)
[2023-04-11 17:54:33]
Hello, I don't quite understand where the 5th paragraph is. The manual is not divided into paragraphs.
Could I kindly ask for a more detailed answer. Thank you
[2023-04-11 18:02:08]
Copying Chart Drawings from Other Chartbooks: It is supported to copy chart drawings across charts from different open Chartbooks. It is necessary for the Chartbooks containing the charts which contain the Chart Drawings which are being copied, to be open.
To copy Chart drawings from another Chartbook, you need to specify the Chartbook name with the chart number in the Copy Chart Drawings from Chart #'s box. The general format is: [chartbook name]:[chart number]. Example: Chartbook1:4, Chartbook1:2. There can be multiple Chartbooks with a Chart Number specified, each separated by a comma.
