Date/Time: Mon, 25 Nov 2024 12:02:27 +0000
Simple feature request
View Count: 1684
[2013-05-02 06:18:53]
Miracle 007 - Posts: 17
Please add a "bar range" to data region field. For example if a stock had high of 75 and low of 65, the range would be 10. Please add this feature if possible. Thank you.
[2013-05-02 07:29:01]
This is easily calculated through studies. For what time period do you want to calculate the range?
Date Time Of Last Edit: 2013-05-02 07:29:13
[2013-05-02 13:04:08]
Each candle. How do I set it up to show with the other information in the "chart values" box?
[2013-05-02 16:40:37]
Use the "Bar Difference" study.
