Date/Time: Thu, 28 Nov 2024 17:56:31 +0000
min delta
View Count: 268
[2023-04-10 22:26:10]
User152238 - Posts: 1
i want show min delta as negative numbers and red in takbe how i do it
imageScreenshot (1369).png / V - Attached On 2023-04-10 22:26:03 UTC - Size: 169.98 KB - 84 views
[2023-04-10 22:28:22]
John - SC Support - Posts: 36350
There is not a way to do this directly in the Numbers Bars Calculated Values table.
You can use the Arithmetic Studies to get the data the way you want, and you can display them as numbers in a separate region, but it will not be a table and you will not have the coloring for different levels.
You can create your own table by creating a custom study, if you want to go down this path. Refer to the following:
ACSIL Interface Members - sc.Subgraph Array: Numeric Information Table Graph Draw Type
