Date/Time: Thu, 28 Nov 2024 17:46:37 +0000
Footprint chart design issue
View Count: 281
[2023-04-10 20:31:20] |
MountToba - Posts: 2 |
I would like to attach the total volume, and delta below and for each footprint at the base of my chart. The data is available in the foot print itself, though I have found no way of showing the totals |
Volatilty vs Liquidity 2023-04-08 142951.jpg / V - Attached On 2023-04-10 20:29:19 UTC - Size: 118.63 KB - 76 views |
[2023-04-10 21:45:22] |
The table in the bottom is the Numbers Bars Calculated Values. Refer to the following: Numbers Bars: Displaying Numeric Information Below Numbers Bars For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
