Date/Time: Thu, 28 Nov 2024 18:35:05 +0000
error code
View Count: 299
[2023-04-10 15:53:52] |
User768203 - Posts: 9 |
Hi, i took a trade this morning and had this error every 3 sec printing on??/ Sending 4 order fills to server. First fill date-time UTC: 2023-04-10 15:30:02. Last fill date-time UTC: 2023-04-10 15:36:16 | 2023-04-10 09:51:08.896 HTTP error sending order fills. Response: ERROR: Unauthorized IP | HTTP status: Request completed with the HTTP response status code 200. | 2023-04-10 09:51:09.625 * Sending 4 order fills to server. First fill date-time UTC: 2023-04-10 15:30:02. Last fill date-time UTC: 2023-04-10 15:36:16 | 2023-04-10 09:51:18.913 |
Attachment Deleted. Screenshot 2023-04-10 094426.png / V - Attached On 2023-04-10 15:49:42 UTC - Size: 56.71 KB - 76 views |
[2023-04-10 15:57:20] |
Disable this option: Global Settings >> General Trade Settings >> Send Order Fills to SC Web Server. And then update to the current release using these instructions: Software Download: Fast Update If you are already on the current release, then exit from Sierra Chart and restart it. After this, you should be fine. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
