Date/Time: Thu, 28 Nov 2024 18:41:57 +0000
Every 10 seconds I get this message
View Count: 282
[2023-04-10 14:29:35]
User267907 - Posts: 17
Hello to all.
Every 10 seconds I get this message (see capture). I have closed sierra and opened it, and it continues.
What does this message mean and what should I do?
Thank you for your answer.
Private File
[2023-04-10 15:45:49]
John - SC Support - Posts: 36350
Disable this option:
Global Settings >> General Trade Settings >> Send Order Fills to SC Web Server.
And then update to the current release using these instructions:
If you are already on the current release, then exit from Sierra Chart and restart it. After this, you should be fine.
