Date/Time: Thu, 28 Nov 2024 18:46:53 +0000
[Locked] - Sierra Chart Update Required for Rithmic
View Count: 562
[2023-04-10 14:07:23] |
Sierra_Chart Engineering - Posts: 17205 |
Approximately two weeks ago, we put out a notice requiring an update for Rithmic users. Here it is: Effective April 8, 2023, it will be required to use version 2487 or higher when using Rithmic. For instructions to update, refer to: Software Download: Fast Update Older versions will be locked out on April 8, 2023 for Rithmic users and will no longer connect to Rithmic. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
