Date/Time: Thu, 28 Nov 2024 18:29:59 +0000
Error message after sending orders on simulation mode
View Count: 311
[2023-04-10 09:27:10] |
User480295 - Posts: 12 |
Hi, After entering orders on simulation mode, an error message below keeps popping out in the trade service log. I have send the message log by using " Send for Analysis" button. Please check. Thanks lots. HTTP error sending order fills. Response: ERROR: Unauthorized IP | HTTP status: Request completed with the HTTP response status code 200. | 2023-04-10 17:22:41.466 * Sending 8 order fills to server. First fill date-time UTC: 2023-04-10 08:50:20. Last fill date-time UTC: 2023-04-10 08:51:58 | 2023-04-10 17:22:50.143 |
[2023-04-10 09:58:00] |
Sierra_Chart Engineering - Posts: 17204 |
Disable this setting: Global Settings >> General Trade Settings >> Send Order Fills to SC Web Server. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-04-10 11:34:17
[2023-04-10 12:11:28] |
GoldSquirrel - Posts: 18 |
I have this same error and changing the setting did not cure it. Any ideas how to clear it up? Error pops up even when all chartbooks are closed.
[2023-04-10 12:14:16] |
After disabling the setting restart Sierra Chart and let us know if the error goes away. If not, then the latest update will solve it. Instructions to update: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-04-10 14:23:14
