Date/Time: Sat, 23 Nov 2024 01:40:47 +0000
[User Discussion] - ECI VWAP1.5 Anchor Point Resetting when closing and opening sierrachart
View Count: 320
[2023-04-10 02:10:12]
User550539 - Posts: 31
Hello! Does anyone else have their ECI Anchored VWAP1.5 reset where it's anchored (manual) when they close their sierrachart and reopen it the next use? I've been experiencing this issue constantly and having to re-anchor every time I open sierrachart up again.
Attached a screenshot below, (anchored vwaps are the cyan and yellow lines) for an example of where the lines are anchored randomly upon startup
image2023-04-09_22-08-05.png / V - Attached On 2023-04-10 02:10:05 UTC - Size: 61.25 KB - 86 views
[2024-08-07 16:12:22]
XL - Posts: 13
I thought i was the only one having this issue. Did you find a resolution?
imageoriginal avwaps.png / V - Attached On 2024-08-07 16:12:05 UTC - Size: 206.97 KB - 37 views
imageavwaps after reset.png / V - Attached On 2024-08-07 16:12:15 UTC - Size: 132.54 KB - 36 views
