Date/Time: Thu, 28 Nov 2024 18:54:20 +0000
Crossing fast between diffrent time/values
View Count: 302
[2023-04-09 13:27:43]
YuvalIsm - Posts: 4
Hello
This message reffers only to contracts like SP500 (E-MINI)
i using sierra for a few months in order to trade contracts.
Recently I have found that in order to see much more data I need to change my setting from "None" to "countious contract by date", thanks to your help. but now, with the new changing other problem appeared,
when I skip between Hours (240 min, 120, 60,etc...), its less efficient because it takes more time to download.
Is there any soulution for this problem rather then change my "Tick by Tick" Data Configuration (from 1 tick to 1 minute)?
I need the 1 tick data for the accuracy of Renko, Volume by price and numbers bar study.
Thank you
[2023-04-09 14:49:48]
Sierra_Chart Engineering - Posts: 17206
No if you are using studies and bar period like these there is no solution:
Also data is not being downloaded when you change bar time periods, it is being loaded from the local chart data files.
Date Time Of Last Edit: 2023-04-09 14:50:41
