Date/Time: Thu, 28 Nov 2024 18:47:31 +0000
Live data on DOW
View Count: 361
[2023-04-09 10:33:43] |
UserQMA - Posts: 2 |
Hi, I cant see live data for US30. can you advise me where can I find that. E-MINI Dow from CME is not showing. also can you advise if I have access to Ger40, EUR50 and Ftse along with nasdaq stocks. Do we get live data for currency pairs ? |
[2023-04-10 14:36:11] |
This is a CFD, so the symbol is just what you wrote (US30). You can find this on the "Find Symbol" window under the "CFD - FXCM" section. We are not seeing any issue with this data at this time. Depending on when you posted your question, the market was probably closed for the Easter holiday. It starting again at 17:00 Central US Time can you advise me where can I find that. E-MINI Dow from CME is not showing.
You need to use the "Find Symbol" window to make sure you are using the correct symbol for the trading service you are connected to. Select "File >> Find Symbol" and then open the section for Futures - CBOT. You will find the DOW futures in this section, as they are traded on the CBOT (not the CME like the other indices). also can you advise if I have access to Ger40, EUR50 and Ftse along with nasdaq stocks.
The GER40 and EUR50 are also CFD symbols, so you will find them in the same section as referenced above for the US30. We do not carry any data for the FTSE, although there is the UK100 in the CFD section, if this is what you are looking for. If you are interested in the U.S. Stocks, then you will want to activate the NASDAQ TotalView[/quote] exchange. Follow the instructions for this at the following link: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* Do we get live data for currency pairs ?
We offer free data for the FXCM FOREX. Again, on the Find Symbol window these are under the section for FOREX - FXCM. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
