Date/Time: Tue, 04 Nov 2025 11:54:15 +0000
Manage Chart Drawings Window Keyboard Shortcut Not working
View Count: 599
[2023-04-08 20:45:13]
User835583 - Posts: 16
I am trying to use the keyboard shortcut , ctrl + alt + m, to access the Manage Chart Drawings Window. However, I am unable to do so. Is there any reason why this would not be working as all the other keyboard shortcuts work. Yes I know I can go to tools and click to open the window, but I do like having the convenience of the shortcuts.
Thanks in advance
[2023-04-10 14:20:43]
John - SC Support - Posts: 42737
First, make sure that shortcut is still assigned to the "Manage Chart Drawings" window. The easiest way to tell is to select the "Tools" pulldown menu at the top and check the shortcut that is listed next to the selection.
You can also select Global Settings >> Keyboard Shortcuts and find the "Manage Chart Drawings" window in the list and see what keyboard shortcut is assigned to it. Refer to the following:
Global Settings Menu: Customize Keyboard Shortcuts (Global Settings menu)
If it is setup for the keys you want, then you have to ensure that Sierra Chart has the keyboard "Focus", meaning that it is the active window when you enter the keyboard shortcut.
