Date/Time: Thu, 28 Nov 2024 18:31:02 +0000
Clear recent bid/ask volume on new position in DOM
View Count: 596
[2023-04-08 15:58:49] |
User417302 - Posts: 67 |
I’m trying to have my dom auto clear the recent bid/ask volume columns when I open up a new position without having to manually clear it myself. I have my setting set to enable the clear bid/ask volume on new position but for some reason it never works and I have to then go and manually clear it. Is there a setting that I may have missed that is preventing this from happening automatically? Thanks, |
[2023-04-10 14:14:05] |
There is not an option to automatically clear the "Recent Bid/Ask" volumes on a new position. There is the option to do this for the Current Bid/Ask volumes. Refer to the following: Global Trade Settings Windows: Clear Current Bid/Ask Volume on New Position (Global Settings >> Chart DOM Settings >> Other >> Other Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
