Date/Time: Thu, 28 Nov 2024 18:54:32 +0000
How can I change the colour of the DOM ladder?
View Count: 288
[2023-04-08 14:19:40] |
User799255 - Posts: 24 |
I scoured the manual but struggled to find the correct section. apologies in advance. How can I change the DOM colours after applying on the chart? Thank you |
Capture.PNG / V - Attached On 2023-04-08 14:19:33 UTC - Size: 44.8 KB - 79 views |
[2023-04-10 13:56:27] |
It depends on what you want to change, but refer to the documentation starting at the following: Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Chart DOM Column Separator Lines For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
