Date/Time: Thu, 28 Nov 2024 18:43:17 +0000
Deleting all data, chartbooks
View Count: 354
[2023-04-08 04:50:32] |
WhiteOG - Posts: 11 |
I want to delete all data chartbooks and everything. I want to run sierra charts from 0 with nothing in it. because everytime i delete any chartbook it shows again and my main problem is having issues with data. |
[2023-04-10 13:44:40] |
The items you are stating are showing up because they have been shared with you. Select the following link to see the list of files that have been shared with you: https://www.sierrachart.com/UserControlPanel.php?page=EnabledCustomStudies#SharedFiles To stop any particular item from automatically downloading, select the "Delete" button in the list. To turn off all downloads, there is an option closer to the top of the page that is a button that states Disable File Downloads. You can then delete the items from your local system and they will not show up again. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
