Date/Time: Thu, 28 Nov 2024 18:40:49 +0000
Number bar coloring and max value identification
View Count: 519
[2023-04-08 00:32:20]
User326519 - Posts: 3
I am using the number bars on ask vol bid volume difference (delta). Is there a way to highlight the maximum value of each bar, even if that value is a negative number? I see the highlight maximum value option but it only seems to highlight positive numbers. I dont mind if this is full background or text highlighted but I would like the colors be to be different if possible, say red for negative and blue for positive. Any help would appreciated.
[2023-04-10 13:35:55]
John - SC Support - Posts: 36350
One way to highlight the largest delta (both positive and negative) would be to set your Background Coloring Method to Based on AskVol BidVol Difference Percentage of Max Dominant Side and then set the Percent Compare Thresholds such that the 3rd value is .99, such as .25, .50, .99. Then set the colors such that the Range 3 Up/Down colors give you the coloring you want for the maximum value. It is possible that you could get multiple values highlighted, but they will all be very close to the same number since you are asking for the 99th percentage.
If you want, you could also set the other colors to be the same as the background so you are only getting the maximum highlight.
