Date/Time: Thu, 28 Nov 2024 18:43:37 +0000
use trade activity log
View Count: 319
[2023-04-07 18:38:52] |
User970210 - Posts: 84 |
Hi, is it possible to show selective lastest win loss ratio and win loss percentage from trade activity log on chart as text? it will help to decide next numbers of trading contracts based on kelly formula. thx in advance. |
[2023-04-07 21:17:56] |
Win/Loss Ratio and Percentage are not directly available, but you can calculate it using the "Trading: Winning Trades" and "Trading: Losing Trades" studies. Refer to the information for these studies here: Trading Information Windows: Trade Data Studies You can use the Arithmetic Studies to get the final information. Refer to the following: Using the Basic Arithmetic Studies And if you want to just display the ratio/percentage as a single value in large text on the chart, then use the Study Subgraph Above/Below Bar as Text study. Refer to the following: Study Subgraph Above/Below Bar as Text For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
