Date/Time: Thu, 28 Nov 2024 18:32:03 +0000
Spreadsheet System for Trading - Column O - Formula Length
View Count: 314
[2023-04-07 15:51:22] |
PeaceFrog - Posts: 105 |
Hello, Is it better/ more efficient to have one long formula in Column O or break it up in two between Column O and Column P? Thank you kindly. |
[2023-04-08 08:25:12] |
Sierra_Chart Engineering - Posts: 17204 |
Should not make a difference either way.
[2023-04-08 19:35:44] |
Ok. Thank you.
[2023-04-09 00:26:26] |
If anything there would be slightly more memory used, with two formulas.
