Date/Time: Thu, 28 Nov 2024 18:27:25 +0000
Scaling Issue : Adding NQ + Keltner to ES chart using Independent Left Side Scale
View Count: 525
[2023-04-07 13:33:16] |
TopGunTrader - Posts: 172 |
Hi, I want to save screen space plus see ES and NQ side by side love regular bars however when I added Keltners to original NQ chart and added them to ES chart and used SAME scaling as NQ ( Independent Use in left Side Scale ) they are not lining up with the left hand scale and instead are over top of ES chart. If using left hand scale works for more than one study they should be over top of the NQ above the ES in attached chart. |
Capture.PNG / V - Attached On 2023-04-07 13:33:08 UTC - Size: 146.88 KB - 98 views |
[2023-04-07 13:35:21] |
I want to use the same Keltner for both to see which might have overshoots of bands and thus are stronger/weaker. If ES isn't at lower band but NQ is and starts to bounce I'd be buying the ES due to relative strength. Seeing both trends with MA slope color will help me not do so much counter trend trading too! :-)
[2023-04-07 15:28:23] |
The Left Hand Scale only works with a single study. So you can not have multiple studies that are referencing that scale.
[2023-04-07 15:32:28] |
Bummer any chance to allow multiple to work so people can have bollinger/keltner/mas? Is there a workaround in the mean time? Having two symbols up with same ma's or bands would be VERY useful to traders. It also saves screen space so we could have fast 5 sec charts up, 1m and 5 min so THREE charts vs 6! Thank you for replying so soon LOVE you guys support better than anybody else. |
[2023-04-07 15:36:56] |
Another way of doing this is sending ENTIRE chart contents to another chart that way scaling would all line up. Under Study/Price Overlay have Studies/Price Overlay or Studies/Chart Overlay (all studies on chart transfer) I know this option is far harder than maybe allowing multiple indicators to use left side scale. The top first one sets the scale and others use that top to bottom scale that would line up ma's or bollinger/keltners perfectly. |
[2023-04-07 20:38:34] |
We have set this as a Feature Request.
[2023-04-08 12:44:18] |
It may not be as useful as I thought on short term 5 sec charts it will be amazing but on 1, 5 etc and longer charts I don't think as useful as I once thought.
