Date/Time: Thu, 28 Nov 2024 18:41:35 +0000
large volume isue
View Count: 277
[2023-04-07 12:03:22] |
User278398 - Posts: 291 |
hello how can i see only BID TEXT COLOR?(i want to see only 11.2k, and i dont want to see 5157) regards |
[2023-04-07 15:25:44] |
The only way to "sort of" do this would be to set the Ask color to be the same as the background and do not use a Marker and set the text display as "Transparent". The issue is if there are other items displayed where the Ask is being displayed, in which case the text could be visible as it is drawn on top of other non-background colored items. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
