Date/Time: Thu, 28 Nov 2024 18:45:19 +0000
Volume by price peaks and valleys plots
View Count: 384
[2023-04-07 10:47:25] |
User670622 - Posts: 5 |
Hello Support hope you are all well and happy holidays. I have a volume profile chart that automatically plots the valley which is the low-volume area by placing a horizontal line on the chart, next to this chart I have my footprint chart, is there a way to automatically have those valley lines transposed to my footprint chart? they represent my areas of interest and would be a great help if this was possible. regards Mike |
[2023-04-07 15:19:52] |
There is not a way to copy the Extension lines from the Volume by Price study to another chart.
[2023-04-07 17:02:17] |
Thank you for your response I have found a workaround and that is to build the chart from candle sticks apply the volume profile, set up the valleys then hide the candle sticks then insert the footprint study that achieved the same outcome so I'm happy.
