Date/Time: Thu, 28 Nov 2024 18:28:58 +0000
[Programming Help] - Calculate the exit to go long or short using ATR with the spreadhseet system for trading
View Count: 316
[2023-04-07 10:10:53] |
Hopeman - Posts: 166 |
Hello, I am trying to create a long or short output using the ATR with a formula that calculates the average of the candle, the problem is that the formula varies according to volatility and I would like the value of the cell to be maintained as soon as it gives a entry signal, do you know if there is any way to fix the value of a cell in the spreadsheet auto trading system? Thank you
