Date/Time: Thu, 28 Nov 2024 18:51:39 +0000
Setting up simulated practive account, Trade Account identifier???
View Count: 293
[2023-04-06 15:08:31]
jmftattoo - Posts: 94
I am setting up a practice account that in sumulated trading environment to practice for an upcoming evaluation. I would like to set the balance to 50k, was going through the steps and the literature says I need a "Trade account identifier". I am not sure what this is, and it says to contact support. So I am contacting support. What would I enter into the edit field on the set up window for the sim account. and how would I change the balance then to 50k once its done?
"In the Trade Account edit field enter any trade account identifier which is at least three characters. Using letters and numbers only.
If you are migrating from the old server-based Simulated Trading Service to the new one, then use the same Trade Account identifier that you have on the old system. If you are not sure what that is, contact us on the Support Board."
[2023-04-06 17:20:42]
John - SC Support - Posts: 36350
This is the trade account name you want to give to your account. It is your choice on what to use for the identifier.
Continue through the instructions and you will be able to get everything setup.
