Date/Time: Mon, 25 Nov 2024 16:44:13 +0000
Rithmic eval account
View Count: 5642
[2023-12-04 18:33:02] |
Brookwood - Posts: 26 |
Thanks for the prompt reply. I have an account that clears through Dorman. I had connected it already (as could be seen in the SC web portal) but it had somehow become disconnected. I'll try yet again |
[2023-12-04 18:36:56] |
John - SC Support - Posts: 36249 |
You need to ensure that the "Verified Until" date updates. Right now it is showing as "0000-00-00". This date can be viewed on the Main Control Panel for your account on our website, or at the following link: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-12-04 19:09:28] |
By God, I believe that's a wrap. Thanks for everyone's help, patience, and support. -Brookwood |
[2024-02-15 17:01:23] |
Keysz - Posts: 15 |
I've read this post with great interest, but having trouble past three separate SC installations for each prop firm account traded and copied. I have a couple of more accounts that I'd like to copy but keep getting signed out of the fourth installation. I imagine that is Denali related but see that others have figured out a way to set up instances with SIM (not sure how to do this). My other problem is running multiple instances of RTraderPro - which I've seen others have said they were able to do. Everytime I try to download another copy - I can't get past the prompt that says I need to replace the existing installation. |
[2024-02-15 17:18:14] |
j4ytr4der_ - Posts: 938 |
Denali allows up to 3 connections per user. Rithmic allows unlimited as far as I know, BUT you have to disable market data or it won't let you spawn more. Little checkbox on their login dialog for the bottom extra login info.
[2024-02-16 06:41:21] |
Keysz - Posts: 15 |
Thanks! That worked perfectly. As a follow-up, are you using Sierra Chart Order Allocation with Frederik Local Trade Copier v.2? Curious as it seems you're happy with the result of the LTC. I have multiple accounts with each prop firm and want to set it up whereby I can not only copy trades from different brokers but also allocate to all the accounts enabled under each broker in each SC installation. Hope that makes sense! |
[2024-02-16 14:35:33] |
I was at one point but am no longer, as I'm only trading a couple accounts with one evaluation company at this time and don't plan to add any more until/unless the CFTC situation shakes out positively (for us). But when I was using them together, they worked pretty well once I figured out a lot of "little things" that had to be set just right. I had a few odd behaviors I couldn't really track down, but typically shutting down SC and relaunching would fix them in the moment. |
[2024-02-16 16:10:13] |
User624595 - Posts: 207 |
What's the use of Local Trade Copier if using SC Order Allocation? Any link to the CFTC situation? |
[2024-02-16 16:55:07] |
For trading with different brokers/evaluation companies. I was trading evals with Apex, LeeLoo, and Bulenox all at the same time, using the LTC to handle each "master" account (so using all 3 of my allowed Denali feeds) and then each one of those using the internal copier to handle the other accounts at the same companies. A good CFTC breakdown and discussion is here: https://www.youtube.com/playlist?list=PLb8VvY6_wwRY1Fj6yQeg2k5LdRkoUCpyv |
