Date/Time: Thu, 28 Nov 2024 18:40:00 +0000
Payment Method
View Count: 415
[2023-04-06 02:00:51]
BADGETT - Posts: 17
How do I cancel/change credit card numbers at STRIPE --- WITHOUT adding more payments?????
[2023-04-06 08:07:07]
Sierra_Chart Engineering - Posts: 17204
We do not know. If you want us to cancel Stripe automatic payments we can do that for you assuming you are using that functionality.
Date Time Of Last Edit: 2023-04-06 08:07:18
[2023-04-06 13:49:34]
John - SC Support - Posts: 36350
You need to go through the "Automatic Payments with Stripe" process and first remove your old card and then go through it again and add the new card. You can access the Automatic Payments section at the bottom of this page:
https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit
We are not sure what you are referring to in terms of "WITHOUT adding more payments". You should not get charged for anything unless your account is in need of funds.
