Date/Time: Thu, 28 Nov 2024 18:31:07 +0000
How to "Select Files to Open on Startup"
View Count: 421
[2023-04-06 00:05:14]
EquanimousTrading - Posts: 3
I have more than one chartbook open. I would like to save this configuration of chartbooks in this order. And then for them all to open up this way when I open Sierra Chart.
In Global Settings > General Settings I select YES for *open files on startup.
Below that it says (Button) under "Setting Name" column
and it says (Select Files To Open On Startup) under the "value" column)
Clicking on (Button) or (Select Files To Open on Startup) does not seem to allow me to select any actual chartbooks to open. Nothing happens when I click on them.
What am I missing to actually SELECT the files to open on startup?
imageSIERRA.png / V - Attached On 2023-04-05 23:59:11 UTC - Size: 73.39 KB - 86 views
[2023-04-06 13:44:10]
John - SC Support - Posts: 36350
When you click the button for Select Files to Open on Startup you should get a new window that allows you to select the chartbooks to automatically open. Sometimes this window may open relatively small, and you will have to select a corner and expand it.
If you are definitely not getting this window, then select Window >> Reset Windows and then try again and see if you can then see the "Files to Open On Startup" window.
Refer to the following for what the "Reset Windows" does:
Window, CB and CW Menus: Reset Windows (Window)
