Date/Time: Wed, 23 Apr 2025 03:12:58 +0000
paquete de servicio, consulta
View Count: 343
[2023-04-05 20:24:56]
luciana - Posts: 24
Hola
Actualmente tengo el paquete de servicios 11 para ver graficos TPO.
Pero quiero bajar a un paquete compatible con el sistema de autotrading S3.
Cual me recomiendan?
Gracias
[2023-04-05 22:07:31]
John - SC Support - Posts: 39428
From Google Translate:
Hello
I currently have service pack 11 to view TPO charts.
But I want to downgrade to a package that is compatible with the S3 autotrading system.
What do you recomend me?
Thank you
We do not know what package the S3 Auto-trading system requires, so we have no idea what to tell you with regards to this.
But you can change your package at any time. Refer to the instructions here:
To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link.
Or go to this page:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation
You will need to login if you are not currently logged in.
In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button.
The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price.
There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted.
When changing between Sierra Chart Service Packages, the usage time ending date on your Sierra Chart account is adjusted based upon the price differences between the package you are changing from and the package you are changing to.
When changing to a higher priced package, your usage time ending date will be brought back closer in time. When changing to a lower-priced package, your usage time ending date will be brought forward further out in time.
