Date/Time: Wed, 23 Apr 2025 03:19:23 +0000
ratio in an additional row
View Count: 355
[2023-04-05 20:02:20]
User303272 - Posts: 4
Greetings
the bottom rows of the chart show the delta und volume of a candle:
https://www.sierrachart.com/image.php?Image=1680724474649.png
How can I add another row to display also the ratio of delta/volume?
Thanks a lot,
Klaus
[2023-04-05 22:06:13]
John - SC Support - Posts: 39428
The table at the bottom comes from the Numbers Bars Calculated Values studies. As such, you would need to look and see if there is a subgraph for the information you are looking for. Refer to the following:
Numbers Bars: Displaying Numeric Information Below Numbers Bars
