Date/Time: Wed, 23 Apr 2025 03:19:18 +0000
help my ETH perp is getting no data
View Count: 321
[2023-04-05 11:34:12]
User849502 - Posts: 367
John,
I don't look at eth as much as btc. I flipped to chartbook and looked at charts, then I realised nothing was moving or updating. I closed the chartbook and reopened it. And as you see just went to symbol and called up a dom. NOTHING. What is wrong, what do I do? BTC perp is fine.
thank you, but help!
imageeth.PNG / V - Attached On 2023-04-05 11:34:03 UTC - Size: 290.88 KB - 93 views
[2023-04-05 14:39:51]
John - SC Support - Posts: 39428
We opened a chart for that symbol and we are seeing updates. It is not heavily traded, approximately 30-40 trades per minute. But it is currently working for us. Let us know if you are still having a problem.
[2023-04-05 17:43:16]
guess what I did? yes, shut down and reboot hahahah. I could work in IT. Whaddya think haha
thanks mate
[2023-04-05 17:58:53]
rut ro, something deffo wrong here. Eth just stopped again. You know I close the chartbook, and then SC and restarted. I was fine. I now look at it and it's dead as a doornail...
what do you think is wrong? Is the chartbook corrupt? every chart, everything is dead...
[2023-04-05 21:44:00]
Again, we are not seeing any issues on our end. Unfortunately the Crypto data tends to have these kind of issues. There is nothing we can do about it.
