Date/Time: Wed, 27 Nov 2024 17:33:01 +0000
[User Discussion] - Re: Sierra Chart footprint
View Count: 569
[2023-04-04 22:41:54]
User846545 - Posts: 1
Hey, I'm looking to see if someone could possibly help me get the footprint chart Up for the ES.
Specifically I'm looking to make it like this:
I'm looking to make it with the same blue and red color coding.
Date Time Of Last Edit: 2023-04-05 11:11:01
attachmenttmp_1680627308_707D0F6E-92BB-4994-A180-8910EBCE921A.jpeg - Attached On 2023-04-04 22:41:46 UTC - Size: 710.4 KB - 134 views
[2023-04-05 05:01:01]
User688525 - Posts: 258
The file you have shared is set to Private?
[2023-04-05 14:00:23]
John - SC Support - Posts: 36329
Here is the image.
attachmenttmp_1680627308_707D0F6E-92BB-4994-A180-8910EBCE921A.jpeg - Attached On 2023-04-05 14:00:17 UTC - Size: 710.4 KB - 125 views
[2023-04-05 14:03:48]
The information in the top is from the Numbers Bars study and the bottom is the Numbers Bars Calculated Values. Refer to the following for each of these:
Numbers Bars
Numbers Bars: Displaying Numeric Information Below Numbers Bars
In particular, start with the section for Step-by-Step Instructions to setup the Numbers Bars.
[2023-04-05 14:20:09]
ticinotrader - Posts: 392
@User688525
If you are looking for settings as close to the original MarketDelta software's footprint charts as possible, you might want to check the posts here:
https://www.ticinotrader.ch/tag/marketdelta/
Most of them are available to download from the Level 1 section of my site, then you can further customize them for your needs if you want.
I am momentarily working on new additions to the MarketDelta collection as well - they will be posted during the next couple weeks.
List of all footprint-related posts:
https://www.ticinotrader.ch/tag/footprint/
Hope this helps.
[2023-04-06 06:47:18]
User150671 - Posts: 69
That's the "standard" Axia footprint:
https://axiafutures.com/blog/how-to-create-sierra-chart-footprint/
https://www.youtube.com/watch?v=jBS4utCt3eU
[2023-07-17 18:05:52]
User805074 - Posts: 29
But what would be the correct data in (In:112) Current Volume Comparison Thresholds, for other markets like the ZN, ZB, UB, CL, GC, and FGBL, or how to find the average volume per session, to adjust those values to each market, thanks.
