Date/Time: Wed, 23 Apr 2025 03:12:58 +0000
CAN'T SET LIMIT ORDER FOR MB0 - CQG (AMP)
View Count: 382
[2023-04-04 21:53:36]
Chi Bao - Posts: 11
I use AMP, select CQG WEBAPI and try to set Minimum market by order for MBO for ES future but I see the ticker name is different compare to to ticker that i use when i link with Tradovate.
Please see screenshot as attached.
As the result, my MBO not running for over 50 orders as I set. Can you please help! Thanks!
Private File
[2023-04-04 22:05:22]
John - SC Support - Posts: 39428
You need to change the symbol settings for the symbol as it is when you are connected to your trading service. For CQG, the ES is of the form F.US.EP?##.
