Date/Time: Wed, 23 Apr 2025 03:16:02 +0000
Different results from simulated to real mode
View Count: 324
[2023-04-04 20:02:36]
WeroTrader - Posts: 46
I have been observing a critical difference for the results of a routine in ACSIL code.
The routine consists of establishing a limit order at a certain price to reduce position; when i process the data in mock mode i get the expected results but when i switch to real mode the result gives me negative numbers.
Could you help me or give me a guide to understand the reason for this result?
The data is processed with the assets listed in Bitmex.
Thank you for your attention and prompt response.
[2023-04-04 21:49:09]
John - SC Support - Posts: 39428
We really can not say, as it depends on how BitMex fills orders and how your order is being handled by the exchange. You would need to understand these and then compare that to what you are doing in your code.
