Date/Time: Wed, 23 Apr 2025 03:09:23 +0000
inquiring
View Count: 306
[2023-04-04 15:44:03] |
Rogers - Posts: 23 |
INQUIRING I CAN'T THE REAL DATA FEED FOR CURDE OIL APRIL CONTRACT IS NOT AVAILABLE YET I PAID FOR DIENAIL DATA FEED
Private File |
[2023-04-04 17:42:58] |
John - SC Support - Posts: 39428 |
First, you must have a chart or a quoteboard somewhere with the symbol "NYM.CL.F.K23" for the message to show in your log. You will want to find that entry and remove it, as that symbol is not correct. As to the Crude oil, you are looking at the April (J) contract, which is no longer traded. You need to select Chart >> Perform Futures Symbol Rollover and change to the K contract. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
