Date/Time: Wed, 23 Apr 2025 03:01:16 +0000
[Programming Help] - Modifying a Stop Limit Opened Order
View Count: 607
[2023-04-04 14:07:23]
User687593 - Posts: 6
Hi there ...!
I'm working on a Order Modification app to change price of a Stop Limit Opened order, tick by tick, using a keyboard.
I managed to identify the order I want to modify, but no way I'm able to change the price.
Any help will be appreciated.
Thanks.
if( shiftPressed && sPressed ){
while(sc.GetOrderByIndex(i, order) != SCTRADING_ORDER_ERROR)
i++;
if (order.OrderStatusCode == SCT_OSC_OPEN && order.OrderTypeAsInt == SCT_ORDERTYPE_STOP_LIMIT)
s_SCNewOrder ModifyOrder;
ModifyOrder.InternalOrderID = order.InternalOrderID;
ModifyOrder.OrderType = SCT_OSC_OPEN;
float price = 4160.25;
ModifyOrder.Price1 = price;
sc.ModifyOrder(ModifyOrder);
break;
[2023-04-04 15:02:14]
Sierra_Chart Engineering - Posts: 19307
This is the correct way to change the price:
Check the Trade >> Trade Activity Log to see what might be happening.
[2023-04-04 17:01:11]
Oh .. good point.
I've modified the code to print the Log, and I'm getting Price = 0
So, the question is now why the price of the order that I've identified and want to change, has the price 0 ?
Log attached.
Thanks for your support !
SCString Message;
i++;
Message.Format("Order Price: %i",order.Price1);
sc.AddMessageToLog(Message, 1);
Message.Format("ModifyOrder Price: %i",ModifyOrder.Price1);
break;
imageLog File.PNG / V - Attached On 2023-04-04 16:59:04 UTC - Size: 8.6 KB - 97 views
[2023-04-04 21:32:26]
Now, I've included the Internal Order ID, to confirm that I'm getting the Order I'm looking for.
I've attached the Log, showing the Order ID, but the price is cero before and after modifying it.
Thanks for your support.
SCString Message;
i++;
Message.Format("Order ID: %i and Order Price: %i",order.InternalOrderID, order.Price1);
Message.Format("ModifyOrder ID: %i and ModifyOrder Price: %i",ModifyOrder.InternalOrderID, ModifyOrder.Price1);
break;
imageLog File 2.PNG / V - Attached On 2023-04-04 21:32:19 UTC - Size: 12.62 KB - 108 views
[2023-04-05 08:31:28]
User431178 - Posts: 654
%i is not correct for price, should be %f
Maybe remove this line as SCT_OSC_OPEN is not an order type, nor do you have to set the order type when modifying the price level using sc.ModifyOrder
SCT_OSC_OPEN is type SCOrderStatusCodeEnum and implicitly converts to int with value 5, which actually makes it equivalent to SCT_ORDERTYPE_LIMIT_CHASE
Maybe do what is suggested previously by Sierra Chart Engineering and check the Trade >> Trade Activity Log to see what might be happening.
You could also add the code below to print a message to the log if the modify action fails
auto result = sc.ModifyOrder(ModifyOrder);
if (result < 0)
sc.AddMessageToLog(sc.GetTradingErrorTextMessage(result), 0, 1);
[2023-04-05 12:25:07]
That worked ...!
Thanks for your support, really appreciated.
