Date/Time: Thu, 28 Nov 2024 17:34:50 +0000
SIM Mode
View Count: 347
[2023-04-04 09:05:47]
User352238 - Posts: 3
Hello, When I uncheck the "Trade Simulation Mode On" in order to switch to live trading, as soon as I attempt to place a trade, the system automatically reverts me back to SIM mode. I wasn't able to find a solution in the FAQ's so I'm reaching out to you here. Thanks for your help!
[2023-04-04 09:06:01]
Sierra_Chart Engineering - Posts: 17204
Who is your broker?
[2023-04-11 05:20:22]
AMP Futures is my broker. Do you think this has something to do with my issue?
[2023-04-11 14:39:18]
John - SC Support - Posts: 36350
You do not have your Sierra Chart setup to connect to your trading account. Since you are with AMP, you are most likely setup to use CQG.
If this is correct, then follow the instructions at the following link to connect your Sierra Chart to your CQG account, which will then allow you to trade in Live mode:
CQG Trading Platform Service: Setup Instructions
