Date/Time: Thu, 28 Nov 2024 18:29:09 +0000
why do my entry and exit prices show as 410,100 instead of 4101.00 for my futures trades?
View Count: 498
[2023-04-04 07:57:22] |
qhamza987 - Posts: 9 |
Hi, When I export my trades into a txt file via the trade activity log, the prices for my executions show incorrectly. So for example it seems like it's being multiplied by 100? Why is this? For example for ES trade. If entry price is 4101.0, the file shows it as 410,100. Is this only for futures? Because this is the first time i saw this happen when exporting. Thank You |
[2023-04-04 17:10:12] |
Refer to the following: Trade Activity Log: Solving Trade Activity Incorrect Price Formatting and P/L Values For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-04-05 04:34:54] |
Sierra_Chart Engineering - Posts: 17204 |
This is the original price format from the exchange. If you want to avoid this use the Save Log command instead of export. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-04-05 04:35:14
[2023-04-05 21:09:18] |
Reply from Sierra chart support- This is the original price format from the exchange.
If you want to avoid this use the Save Log command instead of export. How can I change the price format? Date Time Of Last Edit: 2023-04-05 21:10:50
[2023-04-05 21:59:54] |
How do I change the MES-CME price format from 4115.50 to 411550.0000000
[2023-04-05 22:10:34] |
Where do you want to make this change?
[2023-04-05 22:13:23] |
In the price when I export the file, I want to display it as 411550.0000000 instead of 4115.50.
[2023-04-06 13:30:45] |
There are no options to set an explicit format for the output from the Trade Activity Log. As you have seen, if you do "File >> Export", you get the the pricing as the exchange actually deals with it, whereas if you do "File >> Save As", then you will get the value that you see in the Trade Activity Log instead. Those are the only options. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-04-07 21:00:13] |
Why does my pricing look like this 411550.0000000, you can see image in the attached file section
Screenshot 2023-04-07 165809.png / V - Attached On 2023-04-07 20:58:35 UTC - Size: 32.36 KB - 81 views Attachment Deleted. |
[2023-04-07 21:26:18] |
What is that an image of?
[2023-04-07 21:34:53] |
that is the image of the trade activity log - I just want to know if my pricing format is like that and if there's a way I can see pricing in the normal view like in normal format I hope you understand what I meann
Date Time Of Last Edit: 2023-04-07 21:40:46
Screenshot 2023-04-07 173356.png / V - Attached On 2023-04-07 21:34:44 UTC - Size: 213.32 KB - 74 views |
[2023-04-07 22:03:02] |
We are extremely confused. The image you last posted shows that you are trading with the "Teton Order Routing Service", but the account from which you are posting is on a "Trial". You can not be trading with the Teton Order Routing while on a trial. If you have another account you are using, then you need to login and post from that account. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-04-07 22:04:32
[2023-04-07 22:42:11] |
the picture was an example of how my price is showing up!!!!
[2023-04-07 22:42:12] |
the picture was an example of how my price is showing up!!!! Do you know why the price is showing up like that??? Date Time Of Last Edit: 2023-04-07 22:42:53
[2023-04-08 03:56:36] |
This is the relevant documentation for this: Trade Activity Log: Solving Trade Activity Incorrect Price Formatting and P/L Values Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
