Date/Time: Wed, 23 Apr 2025 03:01:15 +0000
[Programming Help] - Spreadsheet don´t read rows
View Count: 326
[2023-04-03 14:35:59]
Hopeman - Posts: 166
Hi there!
I have a spreadsheet with the bid and ask volume by price in a configuration with volume that replicates the tape almost perfectly. The issue is that when I do a sum formula that occupies 4 or 5 ASK or BID readings, it does not recognize it because there are rows with zeros, do you know if there is any way that the program can read all the ask that appears on the line skipping the zeros?
Thank you,
imagerows.png / V - Attached On 2023-04-03 14:35:51 UTC - Size: 22.27 KB - 98 views
[2023-04-03 17:21:35]
John - SC Support - Posts: 39428
We are not understanding this. You can use a SUM() function with zero values.
[2023-04-03 18:12:50]
I will approve what you tell me,
I want to clarify that I have 20 rows of spreadseet that interprets the tape and when it reaches number 16 the spreadsheet starts counting again, could you be so kind as to indicate what it is due to?
image16.png / V - Attached On 2023-04-03 18:12:44 UTC - Size: 87.92 KB - 99 views
[2023-04-04 15:54:11]
We can not answer, as we do not know how you have setup the spreadsheet.
[2023-04-04 17:36:06]
I have a graph with the study time and sales volume configured in bar period, the configuration of the bars is 20 per volume, I have this in a spreadshhet that only reads 16 rows of 25, when it goes past 16 it starts reading again from above, that is, in row 17 the same numbering of row 1 appears and so on
