Date/Time: Wed, 23 Apr 2025 03:01:17 +0000
How to easily remove anchor VWAP (ECIVwapAnchorV1.5) from chart?
View Count: 954
[2023-04-03 10:23:13] |
MarkusK - Posts: 106 |
I am using the ECIVwapAnchor study in my charts to create an anchor VWAP. I can easily add the VWAP via the right-click context menu. But is there also an easy way to remove the VWAP again? I know that I can hide the corresponding study via the study settings. But opening the settings, searching for the corresponding study and toggling the "Hide" checkbox to remove the VWAP seems unnecessarily cumbersome. And I have to do it again when I want to re-add it later. Is there any easier way to do this? Like it is for example possible with the drawings, i.e. simply select it and hit DEL on the keyboard to get rid of it? That would be so much more comfortable, especially when using multiple anchor VWAPs at the same time. Date Time Of Last Edit: 2023-04-03 10:23:37
[2023-04-03 16:22:49] |
John - SC Support - Posts: 39428 |
If you right-click on the Header Line for the region in which the study is in, you will get options for the Study, "Remove", and "Hide". You can then hide the study fairly quickly. Refer to the following: Chart Studies: Quick Access to Study Settings Another option would be to setup Control Bar buttons for different Study Collections where the ECIVwap is in one and not in another. Refer to the following: Control Bar: Control Bar Study Collection Buttons and Keyboard Shortcuts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
