Date/Time: Wed, 23 Apr 2025 03:09:23 +0000
Delayed data
View Count: 346
[2023-04-03 10:00:04]
User812728 - Posts: 26
Hi
So I've just activated my data feed but I can only see delayed data on my charts.
Please help
Lance
[2023-04-03 10:13:50]
Sierra_Chart Engineering - Posts: 19307
The reason you are not getting real-time data, and historical data in the case of when using an external Trading service (Rithmic, CQG, Interactive Brokers), from the CME Group of exchanges is that you activated the *Non-Professional* exchange fees. However, you have not verified in the last month that you have a live, funded, futures trading account, which the CME needs in order to allow you data at the lower priced fees.
Refer to the "Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges" section here:
Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges
Rithmic paper trading or trading evaluator accounts are not considered a live funded futures trading account.
Refer to the following for instructions on how to connect once a month to your *live funded* trading account to qualify for the lower-priced exchange fees:
If you do not have a funded trading account or one with a supported Trading service, then refer to this solution:
Easy Solution to CME Funded Trading Account Requirement
Consider the above solution to avoid this problem in the future.
[2023-04-03 11:12:21]
Thanks for your reply.
I tried to connect my live account (AMP Clearing) to meet CME Group market data rules for non-professionals via your instructions above -
I went to global settings - data/trade service settings (which was initially set at SC Data _ ALL Services, so I just kept it at this setting) then file - disconnect - connect to data feed.
However I am still getting delayed data
[2023-04-03 11:20:53]
AMP uses CQG, so follow the instructions here:
CQG Trading Platform Service: Setup Instructions
[2023-04-03 11:42:16]
I cant seem to connect to CQG WebAPI just says 'logon unsuccessful: Too frequent logon attempts'
[2023-04-03 11:43:26]
also says 'logon unsuccessful: username and password is incorrect
[2023-04-03 11:54:15]
You need to contact AMP for help with these particular errors. These are not within our control.
Date Time Of Last Edit: 2023-04-03 11:54:22
