Date/Time: Thu, 28 Nov 2024 19:42:07 +0000
Sierra Chart - log on unsuccessful your log on is disabled contact your fcm
View Count: 400
[2023-04-03 04:28:45] |
User910963 - Posts: 80 |
I just wanted to make sure here that this message could be resolved by indeed contacting my broker. I'd like to trade tomorrow.
[2023-04-03 08:52:56] |
Sierra_Chart Engineering - Posts: 17206 |
Yes definitely you contact your broker for a message like that. In the meantime: To access historical and streaming market data independent from your Trading service. Follow these instructions. Set "Global Settings >> Data/Trade Service Settings >> Current Selected Service" to "SC Data-All Services". Press "OK" And then translate the symbols in your Chartbooks and Sierra Chart using this "Edit' menu command: Edit Menu: Edit >> Translate Symbols To Current Service (Translate Symbols to Current Service) You can then use the data provided by Sierra Chart independent of your trading service. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-04-03 12:27:00] |
Thank you, so much.
