Date/Time: Wed, 23 Apr 2025 03:01:16 +0000
TPO at an earlier time
View Count: 355
[2023-04-03 01:51:18]
User285770 - Posts: 41
hello
I want to see the TPO at an earlier time, at least two months back.
At this moment I can only see one month back
What to do?
imageold tpo.jpg / V - Attached On 2023-04-03 01:50:42 UTC - Size: 361.52 KB - 90 views
[2023-04-03 02:01:36]
Sierra_Chart Engineering - Posts: 19307
Use the Continuous Contract option and make sure it is set correctly. It should be based upon Date or Volume-based rollover:
Continuous Futures Contract Charts
Currently it is not set correctly in your chart.
[2023-04-03 23:26:23]
It does not work
Can you please write me what I should do?
Don't send me a link, write what to do
[2023-04-04 16:55:53]
John - SC Support - Posts: 39428
Remove the TPO and first make sure you have the Bar data that covers the time period for which you want the TPO charts.
If you are not getting data far enough back in time, then you may need to use the Continuous Futures chart. The specific setup instructions for this are at the following link:
Continuous Futures Contract Charts: Step-By-Step Instructions
We are not going to rewrite what already exists in our documentation.
If it is not a Continuous Contract issue, then refer to the following for how to load more data:
Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data
