Date/Time: Wed, 27 Nov 2024 23:38:00 +0000
Sim trade entered but seeing a huge loss in p&l immediately
View Count: 350
[2023-04-02 21:18:36] |
User799255 - Posts: 24 |
Hello, I am replaying and entering sim trades. Can I get some help troubleshooting this please. I have the bid ask displayed and when the trade is entered it shows a loss that doesn't make sense. 50 shares of GOOG bought at 93.94. Bid-ask is at 93.80-93.94. The unrealised loss should be marked at 7 USD not, 350 USD. Date Time Of Last Edit: 2023-04-02 21:20:01
Capture.PNG / V - Attached On 2023-04-02 21:16:19 UTC - Size: 45.88 KB - 87 views |
[2023-04-03 11:32:17] |
Sierra_Chart Engineering - Posts: 17198 |
How that is calculated is explained here: Basic Trading and the Trade Window: Main/C >> Open Profit/Loss (P/L) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-04-12 14:09:24] |
ForgivingComputers.com - Posts: 960 |
Your picture shows a loss of $3.50 (Points). The entry was at $93.94, price is not $93.87, so you are down ($.07) * (50 shares) = $3.50. How do you use Bid/Ask to determine open Profit/Loss? |
[2023-06-21 14:20:37] |
Refer to: Global Trade Settings Windows: Use Bid/Ask for Open P/L Calculations (Global Settings >> General Trade Settings >> General) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
