Date/Time: Tue, 26 Nov 2024 20:34:25 +0000
Transparent drawing tools?
View Count: 1293
[2014-06-19 12:45:24] |
User51760 - Posts: 108 |
Hello Support Team, is it possible to show drawing tools using transparency akin to option > fill color > Transparency x%? Thank you for your consideration, Best, Chris |
[2014-06-19 18:32:59] |
What drawing tool are you referring to? Transparency, generally is not a good thing. It increases CPU load and sometimes the operating system has trouble with it and generates errors.
