Date/Time: Thu, 28 Nov 2024 18:32:50 +0000
CFE data. Vix symbol- Paying for data and all agreements signed & accepted- No vix.
View Count: 638
[2023-04-02 16:49:35]
jmftattoo - Posts: 94
Title says it. I am paying for CFE depth, all agreements signed, and accepted. Account verified. but VIX symbol still wont load an intraday chart. Only thing I can get up on a chart is Vix futures. what or how should I proceed?
[2023-04-03 10:27:45]
Sierra_Chart Engineering - Posts: 17204
Yes, CFE is only for volatility index futures. Not the cash index.
See posts 2 and 3 here:
Discontinuing of Old Sierra Chart/Barchart Exchange Data Feed | Replacement Data Feeds!
[2023-04-04 17:57:38]
VOLX will suffice I guess. How do I enable just traditional VIX?
[2023-04-04 20:46:12]
John - SC Support - Posts: 36350
The VIX cash index is no longer available from us. You will have to use the best option from what we are going to be making available.
Date Time Of Last Edit: 2023-04-04 20:46:37
[2023-04-05 08:24:16]
User688525 - Posts: 259
John,
Which thread should I follow to be notified when real-time VIX data is available?
Thank you
[2023-04-05 10:02:26]
This is now available. We have activated your account for the NASDAQ Global indexes.
Use this symbol:
VOLQ-NQGI
Make sure your installation of Sierra Chart is up-to-date:
Date Time Of Last Edit: 2023-04-05 10:03:15
[2023-04-06 07:27:01]
Thank you for activating the service.
I have updated the (Symbol Settings > Update From Server) as well as confirmed that "Allow Support for Sierra Chart Data Feeds" is set to "Yes". When I create a new Intraday Chart with symbol "VOLQ-NQGI", I receive the attached error. Is another setting or symbol required?
Also, when will VIX for S&P 500 Global Indexes be available?
Thank you
Private File
[2023-04-06 08:05:34]
You need to update your installation of Sierra Chart to the latest version:
Regarding what symbols are available that is up to NASDAQ Global Indexes. You can find them all here:
https://indexes.nasdaqomx.com/Home/ExportGidsDirectory
[2023-04-07 10:30:09]
The symbol is working since updating to version 2488.
Will historical data be made available as the current data starts from March 29, 2023?
Thank you
[2023-04-07 10:43:17]
We do not have any long-term history for NASDAQ Global Indexes. Although we suppose we could check with NASDAQ on this. And see if we can import more. But as of now, the start date is what you currently see.
[2023-04-08 06:18:02]
Thank you for confirming.
Although the chart is now loading, an error is still appearing (see attached).
imageVOLQ-NQGI-Error-02.png / V - Attached On 2023-04-08 06:17:53 UTC - Size: 12.26 KB - 102 views
[2023-04-08 09:32:18]
In the case of when using these symbols with CQG that would be expected. You can ignore that.
Date Time Of Last Edit: 2023-04-08 09:32:27
[2023-04-09 04:25:10]
Thank you
